gimpyrobb
dumpsterlandingfromorbit!
- 27,785
- 749
- 113
- Cincy Ohio
So I have been having issues with my front axle pinion gear. Just before Haspin I noticed it had some up/down play where the drive shaft bolted to the pinion flange. When I got in and looked it over, it seems as if the front bearing had "walked" out of place. I tapped it back in and was good to go till about 3 weeks ago. I was headed up to Columbus and got a loud grinding noise. I had appointments to meet so I removed the spline caps and rolled on. This week while recovering a deuce and hauling it to Kip's, I had no choice but to install the caps and drive as far forward as I could(ended up being 10ft) till forward motion stopped. After I swapped the turbo today, I pulled the front drive shaft. Now the whole pinion will move forward and backward about an inch. I have a spare center chunk to put in but want to make sure I don't screw this one up. Is there a bearing retainer/spacer other than the shims I need to look for to keep the bearings from walking out? T.I.A.
