axle shaft questions.
MarcusOReallyus
816
Virginia
Tear down, remove locking hubs, remove the hub&rotor, remove the spindles, pull the axles out. Remove diff. cover, remove bearing caps, pull the differential carrier out. Now you have reached the tube seals behind the carrier bearings. Using a 1 1/2" shaft or pipe drive the tube seal into the center to remove. Using a large socket to drive the new seal in with the long shaft.
