axle swap M715
rudedog
lincolnton nc
I was wanting to put 2 1/2 tons under my M715. I have seen the one on m715 zone ,but my question is I have seen the frt axles cut rewelded and another frt axle shaft to make them the same as the rear or offset rims to make up the diffrence . Can you do a hub flip or is there something else that you can do to make them close to the same .
1,827
You can flip the rears and use wheel offset to correct the width of the vehicle. The fronts can also be flipped but there will be some machining involved and you would lose the drum brakes. OD Iron makes a 20" wheel that can be inverted and are designed as such that if you install the rear wheel opposite of the front, they will still track the same.
