Hawssie
- 0
- 0
- Clayton, California
I came across a few new Axletech ISAS 4500 independent coil spring suspension systems. These are used in the newest RG31 MK5 EHM MRAPS. They weren't cheap but they should offer a unique offroad experience. I haven't got my hands on them yet but I am thinking of using a bobbed M931A2 as a starting point for these while adding a overdrive Allison maybe 3000 series. It would be cheaper, but more work then using a M1078, my other idea. My first problem seems to be how to set up the steering for the front axle. The rear is designed to just be pinned straight. I would assume the front steering needs to be similar to a light duty vehicle with IFS (GM or Hummer?) including right and left wheel end drag links, a center section and a idler arm and steering gear. The steering gear arm would also seem to need to have the arm parallel to the frame, also like a typical light duty automotive system. All of this is much different then a straight axle steering. I cant seem to find any pictures or starting points for creating such a system. Does anyone have any ideas for parts to adapt or pictures or documentation of a military vehicle using IFS similar to this? Maybe even a TAK 4 system, although I think this competing brand's steering is designed quite differently.
