B Pillar Addon
Assault King
Louisville, Kentucky
I have my B pillar here and I plan on making some straight doors and a roof down at the shop. Is there a straight panel that mounts to this taper halfway up the b pillar to the roof? I've looked at a lot of the TMs for like the 1151/1123 and can't seem to find a part number if it exists. This truck is a m1097r1 with a 4 man soft top on it. I've seen talk of two different B pillars that are made but I can't find anything else on the market. Im at work right now so I'll try to respond as quick as I can and I apologize if I missed something obvious. Thanks
diluted
Austin, TX
Well for the 1151 the B pillar brackets are 6023771 and 6432624-200M1
but you probably don’t want those. I think yours uses the round B pillar tube, which you’d also. Need to buy? Probably want more of a spacer like the M1114
Don’t forget you’ll also need the A and C pillar brackets
Might as well just make your own if you’re already making flat doors.
Assault King
Exactly what I needed, thank you! Looks like my keywords search missed a few on the "find in page"
