bad crack on the right front side of the Goat
goat whisperer
Bremen, Germany
I´m searching for a really bad crack on the right front side of the Goat when it starts to roll.
U-joints are ok, seems to be inside the front diff.
It only happens sometimes... but than the hole Goat shakes!
Something seems to stuck and suddenly dissolves!?
Mike asked me to check the pivot joints at the center diff., I´ll do that, but I´m pretty shure the terrible noise comes from the rigth front wheel / shaft or what else...
Any idea?
1958 M274
North GA
Mine used to make a pretty good pop in the right front too. You could feel it with your feet when it let go if you were sitting in the passenger seat. I was worried about it at first, but determined that it was where the coil spring in the right front suspension fit up into the socket on the body. It was binding in there, maybe yours is too. I greased the area where the spring was obviously rubbing inside the socket when the suspension flexed and that made it a lot better. It still does it occasionally but not nearly as bad. I try to remember to put a little grease up in there every now and then. Hope this helps!
goat whisperer
Bremen, Germany
Thank you... that seems to be a good explanation for that noise :idea:
Sometimes my goat also hang a little bit on the left side and after a ride its gone.
That might have the same reason...:!:
I will check that!
popacom
9
winchester,ky
Might also consider moisture in front diff. Being possi. any moisture can affect the proper opere-
of the diff, also might need lube chg. w/additive
Gamagoat1
44
Kiowa, Colorado
Ulf,
Make sure the rear diff in the tractor is greased. It rotates with the suspension and will seize if not greased. This will make the Goat sit a little sideways after a corner or off road trip. And make a load pop when breaking loose. (Not Good).
There is a zerk fitting at each joint front and rear of the diff.
Mike
goat whisperer
Bremen, Germany
Hi,
I allready changed all the oil from the gearbox, transfer case and diffs... and all the old oil looks good, no water in the oil...
Mike, sorry, I dont understand this: There is a zerk fitting at each joint front and rear of the diff." :?:
BTW. I added lots of grease to the front coil springs and the loud crack didn´t appear again! That problem seems to be solved
Gamagoat1
44
Kiowa, Colorado
Ulf,
Here are a couple of pictures of my rear differential. One shows one of the joints there is one on each end of the box. The other shows the complete gear box in place. The arrows show the joints I'm talking about. The gearbox rotates, with the wheel suspension, in these joints. I used a heavyduty, waterproof grease here. There is a grease fitting (Zerk) on each joint. The veiw of the Gearbox shows it on the right side of the picture. (At the arrow) The other end is hiddin from the camera veiw.
If these are not greased they will bind and eventually rust and lock up. There is no bearing just metal to metal fit.
How this helps.
Mike
