Bad vibration
BATWELDING
Haiti
Good morning, I live in Haïti and we just bought a couple old used 802 gensets. The previous owner said the one ran well until it just quit. Anyway I took it apart and put new piston, rings and bearings in it. And of course all new seals. It starts and runs well but has a terrible vibration. I tried putting new injectors in but that didn’t make a difference. Anyway I’m just a backyard mechanic is there anything I missed or need to change? Any and all input is appreciated.
BATWELDING
Haiti
Yes I pulled the engine out and disconnected the generator head. I thought maybe something was out of ballance on the rotor. But the vibration is still there
2Pbfeet
1,465
Mt. Hamilton, CA
The 802 two cylinder diesel is well known for vibration.
With respect to your video, I would point out that having the engine loose on the floor with some of the weight on a lift chain isn't going to help, but is never going to be a smooth as an inline 4, V-8, or an engine with a counterbalancing shaft.
All the best,
2Pbfeet
cstumpf750
89
The Jersey Shore
https://share.icloud.com/photos/0efYqXzbDG--rn6RdgDqnG1MQ here’s a small video of it running I had a chain hooked to the top because there was no way it would sit in one place
That looks normal for a parallel twin with no balance shaft. They are essentially a vertical paint shaker. A good example is an old Triumph motorcycle with a parallel twin. They practically bounce the front tire off the ground idling at a stop light and buzz like crazy at all other rpms. There is a thread somewhere on here where someone found a height difference with the rubber mounts and shimming eliminated a lot of the vibration. The 802s are prone to “walking” if sitting on their own. If they are on a trailer, the tire will absorb a lot of the vibrations.
