Keith_J
- 1,318
- 113
- Schertz TX
VelociT and myself took part in this experiment in bare minimum wheel bearing/brake service. We didn't have a wheel dolly and since there was insufficient driveway width, it would not have worked anyway. Then there was the issue of a 3" octagon wrench...we found a 3-1/2" so I shimmed it with 1/4" thick strips of aluminum. It worked, only the tape used to hold shims in place tore easily.
Using my 4 ton bottle jack, I raised the wheel just off the concrete, then pulled the nuts/lockring/seal and outer bearing. The wheel came off easily, showing a total mess of brake fluid/GAA/GL1 all over the brakes. Multiple cleanings with paint thinner got the surfaces chalky and grease free. Rivet holes were also scrubbed, degreased and prepped. The shoes still had "Rockwell" stickers and still had original mill marks on the heel and toe sections, meaning the 5k on the odo was in fact the actual mileage!
Getting it back together was a bit more troublesome as I couldn't see the brake shoe-drum alignment but once it matched, it went back together just fine.
Now we have 3 more duals to fight but we can use the plywood/PVC pipe method.
