Battery Cable Replacements?
mane3215
MD
Hey Guys, someone felt they needed the batteries in my m1078 more than I did and cut a few of the cables. I'm using the #'s on the cables to find replacements, but no luck.
Does anyone know where I can get some at? I need the two ends circled in the photo.
simp5782
Feo, Fuerte y Formal
9,325
Mason, TN
Go to your local welding store and buy some cable and new lugs and make your own. Be the cheapest way.
ebay has cheap large cable as well.
Military battery terminals made by Grote are part number 84-9581 and 84-9580
or check with Member Suprman he may have some.
coachgeo
3,404
North of Cincy OH
Ronmar
7,161
Port angeles wa
you could also change out to 2 8-d batterys and get rid of a bunch of extra cabling.
Yep, I believe a pair of 8D’s would fit. That is why those cables are excess for me, I dont need them with 2 batts.
If I were really in a cold climate, I might contemplate a larger bank, but I would also probably contemplate a propane or diesel preheater :). My Hab will ultimately provide preheat, so I am OK with two type 31’s The milspec for these things was pretty large 600CCA for 60 seconds at 0F and 350CCA for 60 seconds @ -40F... Need a large bank to deliver sustained current at those temps...
The OP was lucky, if they had something to cut cable, they could have taken all the copper for salvage... Hate thievs:(
