Battery Charger Output on MEP 003A
60Hertz
Massachusetts
I recently started and AC load tested my "new" 003A genset, but could not determine whether the onboard battery charging system was working. The voltage at the two brand new batteries was 24.1 VDC while the machine was running. (The 15Amp charging fuse is OK). I would have predicted it should have been 2.2 X 12 = 26.4 VDC. Has anyone tested their battery voltage, and what was it? And by the way, the genset picked up and carried the AC load with no problems at all.
Thank You.
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
the voltage should be about 26.4 volts at the batteries when the set is running. Since the fuse is good, the TM has a pretty good troubleshooting section for the charging system.
EO2NMCB
23
DeSoto, MO
I had my gauge stop working while running my mep002 out in the woods this past weekend. Got out the dmm and checked my batterys and they were right at 27 volts while running. At which time a said a thank you prayer.
PsycoBob
11
Auburn, NY
Yet another reason why I buy $2.99 Harbor Freight multimeters. Toss one in every electrical item's toolbox. I'm still arguing with the carb on my -025. :( Nice little 28v set, if I can get it working.
1,191
Floats swell on them, I think.
