battery charging issues
oldshep
Clever,MO
Hey everybody. the batteries on my truck wont charge. they are super start agms and are less than a year old. How do i check the alternators output? what else could cause this? all the cables are new also. thanks
Westech
CPL
6,104
212
cow farts, Wisconsin
use a volt meeter and see the volts when off and when running. that about the only way you will be able to do that with out a tester the puts a load on the charging system. could have a bad alt or voltage regulator. ez fixes
