Battery cut off switch
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
I have. Its a great addition! No more need to remove a battery cable to work on the truck or to try and disable it at a display! Mine is a military one I got roaming around in an MV scrap yard. Wish I could find some more of them. Put it out of site, but easy to reach.
DieselBob
15
Arnold Maryland
I am going to install one after I get the brakes and wheel seals done for the reasons gimpyrobb stated. As far as buying cheap-o anything, I look at it this way. What could be the worst possible moment for an item to fail. say 20 miles from home at night in a pouring rain storm it's 35deg out, on a back road in nowhere and my cell phone battery is dead. Was the money I saved on the cheap-o part worth it. My 2cents
Boatcarpenter
Marlborough, NH
Well, if I tell you where I put mine in this Forum then it would not be a secret anymore would it and therefore not much of a deterent. Suffice it to say I installed a key operated one of about 600 amp. capacity I believe. I just turn it off when I park it either at home or anywhere else and leave the key right in it. I am secure at home and on the road I'm never gone from it long enough to worry about anyone finding the switch and taking off. On very rare occasions I have pulled the key though.
I don't remember the brand but it is of good quality, more than ample for the job.
BC
Speddmon
Blind squirrel rehabiltator
32
Cambridge, Ohio
I installed one right behind the passenger seat very near where the slave receptacle wires go through the cab floor. I used a commercially available one, but when we recovered doghead's wrecker from Columbus, it had the exact same one installed to the rear of the cab of his "new" truck. So I don't know if the one I used is a military one of not, since they use a lot of industrial rated electrical stuff.
M35Brown
Sevierville TN.
I installed a CAT master switch P/N 7N0718 $66.88 new form CAT.
Installed in in the Positive cable, and located on the right firewall.
Had to make one new wire from the switch to the starter.
It has a key, (all CAT keys are the same) but the person wanting to steel your truck, will not have a CAT key. (I hope)
6x6guy
21
McHenry, Il.
I have installed a few, available at auto parts store, but the only problem -
with the 2 different manufactures the keys are interchangable between
both of them ( its like a skeleton key) one key fits all. The switches were
placed betweenbatteries and I still lock the battery accesss door-
it will still slow them down a bit.
But like anything else, " If Somebody wants what you have bad enough,
it will be"- as it was written a long, long time ago. :roll:
bsorcs
13
New Orleans
Re switch installation, can anyone tell me if a deuce alternator is unitized? If no, then conceivably a kill switch with AFD is a good idea.
bill steinkampf
JasonS
202
Eastern SD
I put mine on the battery box which makes it easily accessible and lockable using a padlock on the battery door. The switch is between the negative of one battery and positive of the other.
Albin
TN
swbradley1
Modertator
1,945
Dayton, OH
markmontana
Mesquite, NV/Layton, UT
What would happen to that switch in the winter when you crank up a nice cold Deuce to start it?
No, I really want to know.
I'm just guessing here but I think there is more during cranking than 50Amps.
sw
It's never had a problem in cold weather -- using it in a couple different trucks. Of course it doesn't get colder than about zero around here. There are several trucks with same system and never heard of an issue.
namedpipes
Central Mass.
Computer geek by trade and I live in an area where the truck would grow legs and wander off into the night.
WHEN I get mine in the spring, keyless remote entry hooked up to a relay should do the trick. Maybe with an led on the dash indicating go/no go.
*chirp*
