Battery Disconnect/Isolator Follow Up Question
NY88M998
Orange County, NY
Hi All! Reading last month's thread on the Bat. Disconnet, am running into my own issues..! Anyone know where to find/purchase battery cables, and what rating is required? Local mechanic is saying 4 but he cannot get cables that thick (as he points to the current/stock setup). He installed the battery disconnect switch on the dashboard; therefore I would need at least 20 feet to run back-and-forth between the battery (under the front R seat) and the dashboard. Would like to keep the dial on dashboard ideally. thx!
frank8003
4,984
Ft. Lauderdale, Florida
How much 3/0AWg cable do you want, I got lots of it.
Methinks 4/0AWG run to the cab is way overkill.
I know one can weld with the power taken from Deuce batteries, but Golly, How many amps you stopping?
Coug
4,253
Olympia/WA
battery cables should be 2/0 I believe.
Mogman
9,394
Papalote, TX
Running the battery disconnect to the dash sounds like a BAD idea, that an absurd amount of 2/0 cable
Coug
4,253
Olympia/WA
The kit I linked above is designed to go to where the fording selector switch is located, of if you have the switch then just below it next to the diagnostic port works also.
I think it was about 15 feet of cable total to install in that location. It's all negative cable (unless you installed the cutoff at a positive connection rather than the ground shunt to rear battery negative like is recommended) so even if something happens and a cable gets damaged, you won't burn down the truck or anything like can happen if you short a positive cable to ground.
2/0 cable is absurdly large to begin with. I think it's either the same or larger than my F450 with the 7.3l diesel that operates on 12V. Likely the HMMWV could use a smaller battery cable without any issues, so adding a few more feet shouldn't be an issue (and hasn't been for my truck)
