ramdough
- 1,729
- 113
- Austin, Texas
It looks like crystals. Not road dust. I will clean it to see how long it takes.Are they dusty? Could be minerals fromthe dust crystalizing with condensed moisture… what voltage is the tender holding the batteries at? Wash them off with soap water and a brush and rinse them clean and see if it returns…
This one:what is name/model of charger? I got a low expense on long while back that ruined a battery in storage. Advertising for the product made you think it was a tender/maintainter...... It wasn't..... it was a trickle charger... so overtime its constant charging just cooked the battery.
This one:
NOCO Genius GEN5X2, 2-Bank, 10A (5A/Bank) Smart Marine Battery Charger, 12V Waterproof Onboard Boat Charger, Battery Maintainer and Desulfator for AGM, Lithium (LiFePO4) and Deep-Cycle Batteries https://a.co/d/bG08psw
Should be a good one.
Batteries are $60 Walmart ones.
Nope, it says 12v wich is the generic battery setting.Do you have it set on the right mode, 12v vis 12v agm or 12v lithium?
Yes and no…. They have been on the truck in a garage so not as hot as Arizona.Is it very hot where you're at? I hear batteries only lat 3-4 years in hot climates like Arizona.
Might be time to drop all the cables and load test each battery and if a few bad convert to a 2 battery set up i did and its better now than it ever was !I have a battery tender that I leave on the batteries. They are about 3 years old Walmart batteries.
I noticed crystals forming on the top of each battery. I am wondering if they are overcharging or what what could be causing this.
What batteries did you end up with? Brand, model? Group 31’s?Might be time to drop all the cables and load test each battery and if a few bad convert to a 2 battery set up i did and its better now than it ever was !
I kept the original hawker agm ! just had 1 bad our of the 4 so i went the 2 battery system everyone pointed me to but i kept the 3rd battery in the 12 v position as a back up on the 12 side and for me to draw off of with my house batteries tie together at the flick of a switch so my house can be a back up to start the truck or the truck can charge the truck and house batts at the same time if my other options are down /no solar/no shore/no generator -inverter ! So atleast in any senario 1 out of the 4 will get u back up and running (REDUNDANCY) all ways have plan B.C.D.What batteries did you end up with? Brand, model? Group 31’s?
