Battery wires almost catch fire on CUCV
jgb680
Chattanooga, TN
I suspect that I have a bad starter on my CUCV, but I need some input. The truck has been hard to start for some time now, because sometime the starter will start first try other times I have to click the ignition switch numerous times before the starter will actually fire. Today I tried to start the truck, the starter didn't work, I clicked the switch it still didn't start. The wires connected to my front battery started smoking, the wires on the rear battery were fine... Is this just a bad starter or does anyone have any ideas on other problems?
Flyingvan911
158
Kansas City, MO
I don't know much about CUCV's but it sounds like you have a short somewhere in the starter circuit. Try tracing the wire and look for burn marks/charred wire insulation.
Barrman
1,677
Giddings, Texas
Do the above and check the condition of the rear battery. If it is bad, the starter won't turn very fast and all the load will go to the front battery.
majorhitt
Dallas Pa.
Like others have said check your connections. Every connection should be cleaned then use some anti oxidant coumpound at every joint. Sometimes the starter is stopped on a bad segment, When you try to start it, the starter sits on the bad segment and overheats. It may be time to have the starter checked out.
