Batterys
ultim8gamr
Napa Valley, CA
I bought a battery for mine from NAPA, i don't know if its original type but it gets the job done. 31A is the type/number (?) and i have only found it at NAPA. It is a commercial grade battery for trucks, tractors, and busses.
CCATLETT1984
Saint Clair Shores, MI
yes they can, they are made by Deka. The model number is 6TL, any distributor that deals in deka batteries should be able to order them for you. some dealers can get blemish batteries at a hefty discount. a blem battery, as they are called, is simply a battery that has a cosmetic defect. The defect will not affect the life or function of the battery in any way.
190
Albuquerque NM
International battery dealers can also order in the 6TL maintainence type batteries. At least my local one can, don't know if it's manufactured by Deka or International. They want more for it than I'm prepared to pay just now.
86k10
Bertrand, Nebraska
Thanks i'll check into it. Mine had the 6tmf in it. Not that it needs it, just thought it would be kind of cool to have them big ole things in there and be original.
acetomatoco
Those trays are set up for group 31s also... just look at the threaded holes in the pans...you move the hold down rods and use the second set of holes in the holddowns.. Group 31s were furnished as OE on a lot of em...The dual use is a fine thing...ACE
steelsoldiers
3,962
Charleston, WV
Exide made the 6TMF's in my truck. If you think it's fun to get 2 over the fender of a CUCV, you should try lifting 4 over your head into a 900 series ;) It's a great back and shoulder work-out!
1,806
try lifting 4 over your head into a 900 series It's a great back and shoulder work-out!
Chris, is it heavier than lifting a deuce winch out of a Mercedes trunk?
