Bed Side Panel Storage M1078 A1
TGeorge
60
Gardnerville, NV
My 2006 1078 A1 has 5 swing down panels around the bed, and two underbed racks to apparently store these panels. I can only get one panel to fit in each rack. Am I missing something? 2//5 panels seems a bit wacky.
Third From Texas
6,498
Corpus Christi Texas
I stowed mine once when I had my first truck. Two per stowage compartment, iirc. Don't remember what you are supposed to do with the tailgate.
The stakes and crossmember poles will stow as well. The vertical assemblies remain upright and stow in the forward most slots at the from of the bed.
TGeorge
60
Gardnerville, NV
Thanks, but on my truck only the center slot in each of the two racks will accept a panel. The space above the center channels is too narrow for the hinges, and the space below the center channel has bolts protruding from below for the mud flap mounts etc. Seems like one panel per rack is max. I'll take another look.
Third From Texas
6,498
Odd.
Be sure to slide them in as shown in the diagram (hinge up). I somehow got four to fit (honestly don't recall if the tailgate slipped in there as well).
Wingnut13
562
Strafford, NH
They fit, it takes a bit to figure it out. I stow mine for the winter usually. You do have to pay attention to the hinges and bumpers. You would think it would have been designed a bit better. Seems it wouldn’t have taken much to make it perfect.
Once you do figure it out, mark the ends for the next time.
TGeorge
60
Gardnerville, NV
Thanks, if it is indeed possible I'll keep trying. I have a metal stamp set and when I solve the puzzle I'll stamp the ends with numbers and the trays slots with the same. Hopefully they won't cart me off to the nut hatch mumbling about side panels and tray slots. ;)
