Behr Paint as a "Frame Paint"
VenomInjected
WI
I notice guys are throwing the Behr paint which appears to be over "everything" body frame etc.
Looking to spray my frame soon... POR15 isn't worth it to me, nor is it really my cup of tee.
Anyone spray a semi-gloss Behr Black and use it for a chassis paint? (or flat for that matter).
Thoughts?
~M
Coffey1
497
Gray Court SC
I painted my frame and everything else under truck with semi green.
It should work just clean the grease off really well.
VenomInjected
WI
I'm just thinking pressure wash the frame... wire brush it all.... and then Rustoleum Rusty primer it.
After a few weeks come back and top coat Behr Semi Gloss Black
Gralmk
53
Attleboro, MA
A bit old and maybe your done, but after some surface rust prep. I sprayed frame and cab with Behr, Love it and 7 months CAM01567.jpgCAM01724.jpg
it's holding up well, the rest of the truck we did with a brush!
infidel got me
32
Newberry, Florida
Like Coffee said-- make sure frame is clean, purple power it several times/power wash it several times. Mine was not completely clean and paint didn't stick to well. I re-purple powered and repower washed it, re-painted, and not had any more problems.
VenomInjected
WI
I think I'll wire brush up, clean, and rusty metal prime... then OD 24052 it is.....
I was really thinking black for the frame paint... but seems all the 35a2's ive seen are all just green.... everywhere
AZK9
PRC, AZ
I just finished painting my M35A2 today at sundown! The nice dry weather and warm temperatures allowed me to get it all completed
outside in a three day timespan. It's all covered, topside and under, in Behr (Fed Standard 383 CARC Green ) excluding the cab interior.
The prep work is the most important aspect of any paint job. Painting took only 3 days, but getting it ready to paint took me a little over
a month. I was lucky to have Soldier B (my awesome wife) around to lend a helping hand through all stages of the repainting process!
Make sure the surfaces are super clean and dry. Treat rust as necessary and be sure that temperatures and humidity are within the specs
required for the products you are using.
All that being said... be safe and have fun! [thumbzup]
AZK9
PRC, AZ
I sure hope your aren't leaving us hanging like this with no pics!!! :-D
I did not get a chance to take any pics today. At the moment it's raining on my new paint job!
Before the rain started, it was looking pretty good, but there was not enough daylight for photos.
I hope the rains don't mess up all my hard work. I've got no garage/shelter here to put it in/under. :-(
If the downpour does not ruin the finish, I'll try to take a few pics tomorrow in the sunshine. :cool:
AZK9
PRC, AZ
Sorry it took so long to post this pic of my M35A2. There's been a lot of rain 'pounding the deuce' recently,
but the paint, for the most part, is still looking pretty good.
AZK9
PRC, AZ
AZK9- are you going to 3 color camo it or leave it 383. Either way, truck looks great! Good job.
Thanks!
At first I planned to do it 3 color camo, but since the weather has put a stop to my painting efforts... I've got to leave it 383 green for now.
Also... each day that I see it solid green, it has been growing on me. At this point I'm leaning towards 383.
When I get it out to the Central Highlands of Arizona (it's in NJ until late spring), I might change my mind! :wink:
Gralmk
53
Attleboro, MA
Yes you will see brush marks up close, but more than 25 ft away and they go away! Just use a good brush, not the 99 cents ones! But keep in mind brushing will be tight in some spots!
infidel got me
32
Newberry, Florida
paint brush
Anyone brush this paint onto the frame? Curious if brush marks were present?
Member have stated that they have added floetrol - I think that's how its spelled-- when using a brush and it all but eliminates brush marks. I have not used this additive but others swear by it. Why don't you just spray it? :popcorn:
