Bent drive shaft
rfischba1
Fort Meade MD
Got my M1008 home today and realized the vibration is from a bent drive shaft.
How hard are they to replace?
Are used ones expensive and hard to find?
What can I expect to pay for a used shaft?
Can you drive short distances with a bent shaft?
JAsher45
Redfield, Iowa
to replace the shaft is just a matter of 4 bolts on the pinion flange and the u-joint and shaft fall free. then it just slides out of the back of the transfer case. You should be able to pick on up at a junk yard no problem... just make sure you measure first... i had to replace on my M1009 one of the balance weights came off.. i went to a local race car shop and had them build me one from scratch... new yoke and ends.. balanced and out the door for $155..
you can drive a short distance with a bent shaft... but dont not recomend drive any more then you have to... the vibration is moving to your transfer case and rear end... where it will cause premature wear to bearings and seals
