coastalconstruction
- 0
- 0
- anacortes wa
Whats the best ehgine (stock) to lookfor ? Im looking for a duece and havnt owned one yet.
Assuming you run strait diesel in the multifuel. The non gas engines have to be cheaper to run if you use WVO or used motor oil.acetomatoco said:lowest cost to run of the Deuce engines..
Yepacetomatoco said:The OH331 Reo gasser installed in 1950 is the quietest, most reliable, lowest cost to run of the Deuce engines.. The LD-465-1A would be my next choice... also quiet and reliable with a muffler and no turbo to worry you....
Sorry Joel but that is incorrect. The -1C or -1D suffix following the LDT465 has NOTHING to do with the turbo. The -1C or -1D (or -2 in the case of Bjorns XM-757) refers to the engineering change level of the engine; i.e. the level of change/upgrades made to the engine when it was originally built. The "C" or "D" turbo refers to the version of the turbo but the turbo version is not tied to the engine version.BFR said:LDT465 C (assuming you have already lost, or do not need your ability to hear) or LDT465 D (basically the same w/o the shriek)
