Best forum around for information
Cape Girardeau,MO
This Saturday I'm buying my second M37 but it has one problem. The engine is stuck and was wondering if there is a good way to unstuck the motor. I plan to get a bottle of Mystic Oil to dump in the cylinders to hopefully unstick the motor. Is there something better? I also plan to pull the truck instead of trying to use the starter and was wondering if using the lower gear in the transfer case would be better or keep the transfer case in the high range? I remember doing this years ago but it was a automatic so we couldn't pull it.
Any help would be appreciated.
On another surprising note the vin tag has US AIR FORCE stamped into the tag ...way cool I'm going to have a blue M37. If I hadn't started painting my current M37 OD green I thought about White for SP or gray for dock side Navy
Thanks to anyone who responds
Chief_919
100
Western NC
Kroil is fare better than Mystic or anything else.
Get two of the 8oz bottles and dump about 2oz in each cylinder. Let it sit a week or more, then try it by hand first.
Be patient. It took a lot of time to seize up, it will take time to unstick without breaking a ring.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
50/50 ATF & Acetone. Park it in a high gear facing down hill and forget about it till shes at the bottom of the hill.
Floridianson
2,485
Interlachen Fl.
Sorry. What ever you try go easy. Also if you find you want to pull her I would use reverse gear and pull forward or a forward gear and pull backwards.
gerrykan
SGF, MO
I have seen a flathead Dodge engine that was stuck due to a valve being stuck in the closed position.
You can find out if this is the case, by turning the crankshaft backwards using the bolt on the front of the crank.
The motor will rotate backwards until the cam lobe returns to try and open the valve again.
If the bolt loosens first, then this is probably not the problem.
If you try to pull start the truck, be careful of to much speed and don't pop the clutch suddenly or you may bend a rod.
