Best place to drill the exhaust manifold for the exhaust temp sender ?
1951M1078
185
Glendale,AZ
Working on my M1078 / Cat 3116 and need some input on installing the exhaust temp sender.
The fitting I have is a 1/4" NPT. But where is the best place to cut the hole ?
Can I use grease to hold the cuttings to the tap ?
Or do I need to pull the header ?
Thanks, Randy
snowtrac nome
139
western alaska
the ones I have seen are all right behind the turbocharger usually just before the elbow down or right after it I know a lot of kits say drill the manifold all the oe installation's I have seen are in the pipe
scottmandu
36
Texas
OEM diesel installations require measuring exhaust gas temps at the inlet to the exhaust gas treatment equipment. This is why many sensors are installed post turbo.
If you want to know true EGT, then you want to measure the temps immediately after the exhaust valve and before the turbo. Turbocharged gas powered Audi/VW/Mercedes/BMW/Porsche etc all have factory EGT's installed between the exhaust valve and the turbine inlet. This is in the event the EGT's get too high the computer can compensate with a reduced power output to cool things off as there can be a significant temperature difference of the exhaust temps pre turbo to post turbo.
coachgeo
3,461
North of Cincy OH
Compromise??? drill hole in Ex Manifold but weld a?? around it for extra strength? or...... do post turbo but calculate how much loss in temp between post and preturbo and compensate for that when you watch your EGT guage?
