best way to apply carc
jay741
RI
hi i have a a cucv truck on the way just waitin on the euc. i was wondering what the best way to apply carc is. i dont think a paint brush is the way to go. Is the sprayer the way to go the truck is all green. where could i get the cheapest sprayer???? also what color is the underneath of the truck oringal paint??? thanks
DonMn
St.Paul,MN.
A spray gun is your best bet, you can get by using a cheap spray gun they spray just as well as a qaulity one, the main difference is you can't rebuild a cheap one, or better put it's not worth rebuilding. I've been using a cheap ATD for almost ten years, I even used it on a professional level for about 5 years as my deicated primer gun.
If you go the HVLP(high volume low pressure) route make sure you have an aircompressor that can keep up with it, HVLP's use a lot of air compaired to conventional guns.
Check your local craigslist.org you might find a nice old quality spray gun something like a Binks, Devillbis or Sharpe.
Don
Jones
Sacramento, California
"Resource" tab at the top of the page then go to the tech bulletins section of the SS library. There are S-W CARC data sheets there and they have all you need to know about applying CARC... even spray gun orifice size and the best reducers to use.
ralbelt
9
West Warwick, R.I.
Ditto on the HVLP. CARC lays down very easily, I did part of my M1008 last week end and will do some more this weekend. I removed the rear box, only 8 bolts two wire connections and 4 screws at the fuel fill. That way i could pressure wash the chassis wire wheel it and spray it Black which was original. I also could do the same to the bottom of the box and spray it CARC green.
yeager1
Colorado
Definitely spray it on. A $40 HVLP automotive gun will do, but don't get one of those $20 latex guns. Prep is absolutely key to get carc to stick to the old coat. You need to either prime everything (which I wouldn't recommend unless the old paint is fairly bad) of scuff everything with scotchbrite (the maroon color works best). This will give you excellent adhesion and it is fast to do. Without good prep, don't even bother, it will flake off. Also, this type of CARC is IMO the best:
MIL-DTL-64159, Type II - Products - Product Finishes
poppop
39
Brooklet, Ga
If you are going to sand or spray real CARC read up on its dangers. It is best to use fresh air supplied hoods when working around it. If not then I would keep it wet when sanding and at least wear a very good fitting face mask when spraying.
bigmike
354
Dixon CA.
I painted my deuce and M105 trailer with one Harborfrieght gavity fed spray gun ($9.99 on sale).
I loved it. Easy to clean, easy to use. I didn't go with HVLP but seemed to have great success anyway.
1,131
CARC calls for a 1.8-2.2 tip. HF's cheap guns are 1.4.
I've shot CARC through the HF guns but if you can find a cheap gun with a bigger tip, that'd be better.
Guyfang
23,908
Burgkunstadt, Germany
CARC has always been a problem. The Army in Europe can only get things sprayed under strict controls. And Soldiers are NOT allowed to do it. Only privet company's, that can do it with all the safety measures that are required.
Since 2000, high-performance water-reducible CARCs were commonly used. These materials met DoD’s VOC objective of 1.8 lb/gal and contained no hazardous air pollutants.
