ke5eua
- 41
- 48
- Baton Rouge (Central), LA
Ok, I did a little search but nothing pertaining to the 818 truck.
I sprayed the bolts that hold the plate over the tank today with some wd-40 and tried to remove the bolts with my ratchet and wrench and it was a no-go.
Little timid to take heat to it as both tanks are full and I've seen first hand what happens when you mix fire and fuel, I used to play in fires before I hurt my back.
So I'm thinking about taking my impact to it, and just taking the entire spare tire, tool box assembly off.
If anybody has any tips, or suggestions I'm all ears.
