Isaac-1
- 50
- 48
- SW, Louisiana
I had some time today to check over my "0 hour" MEP-016d today. I had already discovered that it was not really 0 hours thanks to the coating of sand and sludge in the fuel tank and clogging the fuel filter. I had also discovered the wiring diagram plate loose and rattling around in the control box. What I did not expect to find was the creatively engineered very neatly done professional looking wiring I assume done by the contractor that did the Yanmar diesel conversion 7 years ago. It seems they installed a 10-40VDC hour totalizer between the hot and neutral connections on the panel mounted outlet, better yet, they wired the outlet up using the same 24 gauge instrumentation wire as used for the hour meter, and ran both the neutral and the hot sides through the panel mounted fuses. All done with nice professional looking custom length fiberglass wrapped wiring.
So what sort of creative wiring have you found on surplus equipment?
Also any fellow MEP-016d owners, how is your hour meter connected, is it an AC meter connected similar to mine, or is it a DC meter, if so connected where?
Ike
Ike
