Big crane truck
NDT
6,262
Camp Wood/LC, TX
P&H 855? Actually that capacity lattice boom crane truck is still in demand for tilt wall building erection. Your example needs some love . . .
trog
Vernalis, CA
It was bought "off the shelf".
If your P&H has hydraulic actuated controls like mine, originally filled with DOT 3 brake fluid, then I suggest switching to DOT 5. Sticky, corroded slave cylinders can be dangerous, for example, in losing control of the swing.
Another maintenance item is turntable grease. Common grease is a mixture of oil and calcium soap, and it hardens when the oil is lost over time. Hard grease can cause the roller bearings inside a P&H turntable to bind, and that can be dangerous. New oil may soften up old grease.
