bigger front springs, need source for studs
Bob H
159
Ran into a snag here on the M882 plow truck
replacing the front springs with a set of 1 ton springs.
6 leafs now, at the differential there is one U bolt and a pair of studs on the other side.
These 9/16 double threaded studs are only 3" long, which is not long enough.
need at least 3-1/2" long.
Can't find anything anywhere over 3" long
82814218.jpg this is the stock one
below is from a discontinued Dorman # 675-048 listing
A=9/16 UNF by 1-1/2
B=9/16 UNC by 1-1/4
C= 3-1/2 inch
I know the expensive lift kits have the longer studs, but have been unable to find out how to get just those studs from them.
nattieleather
138
Cleveland, OH
Bob try doing a google search for Dorman #675-048 and see if anything pops up. Someone might cross reference it. Or if you have a shop near you that does leaf springs and hardware they might be able to make the stud for you.
Bob H
159
Can you just use a grade 8 bolt with loc-tite?
So far I have found that a couple lift makers supply a pair of Grade 8 bolts for this function. Which is likely the way I'm going. Not the best or safest, as a single course threaded bolt can't be torqued like a stud with fine threads at the nut.
I would think you would be able to go to a bolt store like Fastenal and order what you need
the 3" long I listed above is all any fastener company makes (yes they can be special ordered, but I'd make & heat treat my own before I pay over a 100 $$$$ for a pair studs.
I just went to a local car quest and picked mine up
I need longer than the industry's 3" long ones which is all every place I've tried can get.
Give
Mid-States Bolt & Screw Co
360 S Outer Dr, Saginaw, MI 48601
Phone:
(989) 753-3492
Toll Free: (800) 324-3233
Or
Michigan Truck Spring a call
1-800-358-4751
http://www.truckspring.com/?keyword...Y7eoZo7Uuox5Iv8MBKJPITTbXEbgWxiTITxoCO3vw_wcB
Tried, Got someone, "less than bright", did you buy the kit from us? No, I want to buy the studs supplied in the kits. "You have to buy the kit", running in circles. May try again tomorrow, but I get the feeling if I get anywhere with them the price may be stupid.
edit: just tried again, no help
Most lift kits would have them, but trying to get one of the places give up info on how I can acquire them has proved challenging.
Bob H
159
A quick seatch found this on summit racing the part is made by ARP ARP Individual Studs AQ3.475-1LB
Hope this helps.
Well shucks! I spent over a half hour on summit's site and couldn't find this.
(didn't even think of head studs)
Thanks, I'll be ordering them to replace the old used ones I ended up getting!
RQQ
Charlotte, NC
Great thread for what I need. But I need the stock size studs. Do y'all have the specific part number for that and/or a supplier? And I saw that the Summit studs were cromoly which sounds better than grade 8. I lost both studs yesterday on a trip and luckily the ubolt held and the spring plate got caught on the leaf spring center bolt and I was able to get back to my trailer without problems. BTW I have this diff on a Jeep.
Thanks,
Richard
cajuncustom
Port Barre , La
Thanks,
Richard
When i got mine i picked them up at a local parts store they were cut to fit bigger then stock so it worked just right
