Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
I am going to replace the left front rear wheel cylinder on my M35A2. I will first bleed the air cylinder and then the new wheel cylinder. Do I have to bleed the other wheels too? If yes, then which wheel do I start on after the air cylinder?
Chances are you will not have to bleed the entire system. Just depends on how long and how bad the leak was. If you have never bled the system then it may be a good idea to do everything.
This is the order for bleeding a single M/C Deuce
Airpack
Far right rear
Far left rear
middle right rear
middle left rear
front right
front left
All covered in the TM 9-2320-361-20 or the TM 9-2320-209-20 tech manual
Have you made a Bug Sprayer power bleeder? They help A LOT.
Here's my bug spray power bleeder. It worked ok but i need to add a quick disconnect. It got a little messy taking it off. Brakes are fine now. Thanks for the input.
