Blinker no blink, blink
sermis
17
Temple, TX
OK the left turn blinker will not blink. Right works, stop lights work, tail lights work, but left will not work. The light on the turn signal switch will light up but no blink. It was doing this before the sand blasting and painting. I put in a new turn signal switch and the same thing. Took it for a little drive and on one turn if blinked four or five times and then quit. What is going on?
alphadeltaromeo
Alto, GA
I'd say if the light actually comes on and stays on..it's the blinker unit...especially if the rest of it works like a charm. Mine has failed working all together. It used to just blink intermitt...but now, it just keeps the lights on and the ground is good.
cranetruck
75
Meadows of Dan, Virginia
sermis said:
OK the left turn blinker will not blink. Right works, stop lights work, tail lights work, but left will not work.... quote]
The flasher unit is channelled to the left and right, if it works on one side but not the other the wiring and/or the bulb(s) are bad not the flasher unit itself.
I have low confidence in the new units and have installed relays on my trucks to relieve the load stress on the flasher, as a result I don't have to worry about overloading it and I get a slightly higher voltage on the lights to boot.
KaiserM109
SE Aurora, CO
Your problem sounds like a bad connection or a combination of weak connections. Your symptoms really point to a bad contact in the turn signal switch.
I am speaking more from working on Jeeps and Broncos, so take it for what it is worth. A deuce flasher system is identical to Jeeps and Broncos from what I have seen so far, except for the voltage and those COOL double element bulbs.
American electrical systems use beryllium-copper for contacts. It makes them less corrosive and springier. If you want to see why that is useful, work on an ‘80s or ‘90s Mercedes electrical system that uses pure copper! Beryllium-copper will still oxidize to some extent and will eventually break the connection. Two contacts firmly pressed together can loose contact after about 25 years.
Also the problem is cumulative, meaning that ALL CONNECTIONS INCLUDING GROUND should be opened and cleaned. A ¼ inch drill with a 17 or 22 caliber bore brush is great for getting down into tight connectors. Also do a thorough inspection of all wires. A cracked or pinched wire will let salt in and the wire can be significantly degraded. Crimped terminators can be making poor contact for the same reason. The solution there is to buy acid-core solder and solder over all crimped contacts. Don’t open them, just solder over them.
You say that you put on a new turn signal switch but it could still be at fault, especially if it was a pull-out. It could have the same problem, even though it was working in the other vehicle. I recently bought a “re-pop” (brand new 3rd party manufactured) turn signal switch for my Bronco that had exactly the symptom that you are describing. I had to re-work it because the contacts didn’t quite make.
You can confirm the switch’s operation with an ohm meter. On a single contact with no more than 6’ of wire, you should not see more than 0.2 ohms. Remember to measure the resistance of your leads first. If none of this works, get a diagram (someone on this link will know where to find it) and trace it out. Watch for excessive resistance.
I like cranetruck’s solution. Early GM starter systems, which Jeep purchased, ran the starter solenoid current, several amps, up through the ignition switch. It worked fine for the first 10 years of the vehicle's life but would drive you crazy after that. A Ford starter relay mounted on the fender was the solution. Cutting down the amount of current that you are running through the switch can be very helpful, especially when you pull trailers.
m-35tom
222
eldersburg maryland
turn on 4ways, if all work problem has to be turn control switch. if brake lights work on both sides problem has to be turn control switch. brakes and turn use all the same wiring.
sermis
17
Temple, TX
4 way no blink. Left no blink but light on switch comes on. Right blinks. Stop work. Left will blink every 10th or 15th turn about 4 times and quit.
m-35tom
222
eldersburg maryland
if you turn switch to left or right the brake light on that side should quit working, if so, bad switch, no other possibility.
