Blow by tube
beastm35
plainfield ct
From the top of motor down the slobber tube there is two threaded holes one with a copper line hooked to it and the other the one above that is open and blow by is running down the tube. Should this hole by capped?This is on a muiltfuel motor non turbo.. thank's
1,177
No, but you can if you want too.
Do you have a rubber extension hose below the slobber tube(steel)?
You should have one that goes to the bottom of the axle(length).
Again, no big deal if you do not, but you can add one.
FloridaAKM
392
Gainesville, Florida
Both of my trucks didn't come with the slobber tubes for some reason. McMaster-Carr has blue silicon 1 1/4" tube that was added to both trucks to route the blowby to in front of the battery box & out of the way. It may not be original, but it suits me & works well.
