hoplite666
- 1
- 18
- Fairfax VA
Years back I did the dog head mod. I had had a run on starter and melted the fusible link going down to the starter solenoid.
I replaced the damaged wiring and installed an inline 30amp fuse in place of the fusible link that had been there from the factory. Every six months or so that 30amp fuse will blow. Pop a new one in and wham bam thank you ma'am its good to go again for a period of time. Today I go to leave work, turn the key and nada. Check the 30 amp fuse and its blown. Get another one from the glove box, pop it in. Give the key a turn and nada. Blew that fuse too. I did this several times all with the same result. Decided I'd use a paper clip to jump it just to get home. Well the paper instantly melted when I turned the key. So I get a ride home and here I sit.
No signs or nothing out of the ordinary leading up to this. About a week ago I did the glow plug resistor bypass and installed the LMC headlight harness but this should be entirely unrelated.
Time and tools are limited at the moment and until I get my laptop squared away navigating this site and the TM's on my aging smart phone is a pain in the butt so any quick thoughts or places to look first would be greatly appreciated!
