acthomp781
- 30
- 18
- Massillon, OH
Hello all. 1986 M1009. I searched quite a bit and found nothing specific to my problem. I installed an autometer water temp gauge. I tapped into the tan/white wire for ignition feed, right under the fuse panel. I ran a ground wire all the way to the location where I installed the sending unit, on the same stud that have two other grounds to it, one being a "braided" wire to the firewall. I purchased a pipe flange and installed the sending unit in the right head at the rear of the head. The ignition fuse, number 15 on diagram in 289-20, 4-31, now keeps blowing. When it does the wait light and water in fuel light will not come on, nor will the transmission "kick down" when going uphill. The PO converted to 12 volt system(working on getting back to stock). Otherwise stock system. I also installed a new GP controller card from BMI industries. The vehicle will start right up as I can hear the GP relay cycling, but no wait or water in fuel lights and new gauge not working. The only thing I can think if I put the ground wire for the new gauge to the sending unit and the wire that is supposed to be attached to the sending unit to ground. Thank you for your time.
