Bob or not to Bob 5Ton
US6x4
2,213
Wenatchee, WA
I'd say don't do it. You'll lose 1/3 of your traction and maybe 3000 lbs also but that may not improve your mileage like one would think. I personally like the 6x6 truck. Every guy and his dog has a big 4x4 around here but not many have a 6x6. A big M715 would make a cool military 4x4 if that's what you're after.
53
21
South carolina
I wanted a reason that would sway me to 4x4 but I like the 6x6, I planned on doing a crew cab on a m52 bc I also am going multifuel. I'm a Fab/welder for cat so design isn't going to be a problem. If there are no gains them I'm good.
tobyS
833
IN
Bobbing is technically cutting the frame shorter. I'd use a M931 and not cut it. Then you have a really nice pintle hitch ready to go + air brake control for a trailer. M105 beds look good on them. I do like the 4x4, reducing weight, drag and cost of 2 tires. And the 5 ton can cruise at highway speed. Air ride would be nice too. That said, I've had several 5 ton that it could have been done to and I couldn't pull the trigger. My 4x4 project is an M35A3.
Edit....If I recall, you are working with an early version 5 ton, not the later M939 series....right?
I still like the 4x4 idea....I'm not politically correct however.
Elijah95
Certified Rookie
1,239
1,184
Georgia
Plenty of trucks are already bobbed, it’d be better to “rebuild” a bobbed truck than cut up another.
Jbulach
2,167
Sunman Indiana
Another vote not to neuter here! After seeing how well 6x6 does off road, I think I’ll still have 6 tires on the ground when the Bob’s are up on 2 or 3.
azteclizard
Yuma, AZ
The M52 is already shorter, so technically your nit bobbing it if you just convert it to 2 axles. If you are going to make it some sort of quad cab you will never need the full weight capacity, so removing an axle isnt all bad. Just use decent springs(not trailer springs) and all will be fine.
It is after all your truck.
Robo McDuff
In memorial Ron - 73M819
1,499
Czech Republic
There are some nice examples of 5-ton crew cabs on the site. DaveP has a nice tractor with sleeper with a trailer behind it (I think it is an M54 long frame to make room for the sleeper and still keep the fifth wheel.
Bob or not, it all depends on what you want to do/achieve with the truck, it's your toy.
