bobbed air ride crew Deuce
Jbnks9134
Clovis comiforina
Hey guys is there any body in central ca that is a m35a2 lover as I am I'm doing a complete overhaul and modification of my m35a2 bobbing it crew cab, brownie, power steering conversion, and a complete rewire, using the stock bed being cut down to fit. I'm looking for a larger turbo and a set of 395/85/20 to finish it off. Pics to follow thru the build
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Cool.
Can you explain how you got the (I assume) power steering pump in there?!
Thats one hellofa tight area.
Jbnks9134
Clovis comiforina
That power steering set up is off a 1989 F700 with a 429 it's mounted by 2 pieces of 1/4" 4" plate drilled to bolt to the timing cover. So far it has 0 deflection. As for the stock filters after i get the rest of the cab built I will be ordering the adapters
rustystud
2,959
Woodinville, Washington
You should give us some more up close pictures of the mounting. That is a very slick look, just like factory !
