bobbed deuce 4 wheel drive?
supeman100
Austin Texas
ok guys I am having a bobbed deuce built for me but I have a question, I know its 4wd but how do you engage it? I have seen videos of bobbers going through mud with only the back wheels spinning and then the front tires lock in.
please excuse my newbie knowledge on these trucks but can someone explain how to engage the 4 wheel drive and how it works?
thanks!
1,172
Let's capitalize, like the rules request.
KsM715
142
St George Ks
Unless it has a sprag t-case. That allows the rears to spin some befor it catches and spins the fronts. Either way the deuce has one of the 2 cases. Older versions had a sprag and the rest have the air shift model. If it doesn't have the air switch at the bottom center of the dash then most likely it still has the older sprag case. But if it's being built from parts there's a chance it has the air shifted case but the builder never put the switch in. In that case it's 2wheel only.
