My truck is near done w/ the Bob job, and I'm going over all the small things and making a list. i have to get new U-bolts because the one I had copied was done wrong and came out square instead of semi-round. Having a look at all that got me to wondering about my spring perches.
I did a bunch of trading to get my Front spring setup and ended up without front spring perches. I called Eastern and had a pair sent over. When I was installing the axle I just set them over the little alignment tabs on the axle and rolled the thing under the truck. I found out quickly that the alignment tabs didn't allow the spring to align correctly to the frame. SO.... i cut the little tab off the axle tube, center the axle in the frame, and clamped everything together.
My questions is:
Do I need to weld the perches to the axle tubes?
If so i'll have to go w/ aftermarket because I'm sure the cast iron isn't going to weld well. I've done a bunch of looking around over the last few years and am surprised no one has discussed the problem of the alignment pins on the axle or the perches.
My questions is:
