Bobbed Deuce Brakes - an easy fix for you guys and gals
wehring
26
Angleton, TX
I just made a plug for the rear brake block that branches the single line to a "Y" for the rear axles. When you Bob a deuce you only need one outlet. 1/2x20 threads and a 45* concave end is what is needed in a plug to fit in the extra port. I could not find one commercially so I just made one out of a stainless allen head bolt.
Be careful removing the old line from the block. Hold the block securely while removing the line or you will snap the block off of the bracket holding it to the frame. :oops: Ask me how I know. Thankfully it was on my engineering unit.
Justin
