JasonS
- 131
- 63
- Eastern SD
I spent the last week swapping out my OA331 for a completely overhauled later model OH200 engine. The OH200 is a later generation gas engine incorporating numerous improvements over the OA331:
Larger mains (3.125") and rods journals (2.30") with hardened journals.
Larger oil pump (15 vs. 7.2gpm) with full flow filter and oil cooler.
Larger capacity water pump (150 vs. 70gpm) with larger bearings and shaft and ceramic faced water pump seal surface.
Chrome faced top piston ring with steel insert for top piston ring groove.
Bypass-type thermostat (same as multifuel), improved cooling/ water distribution.
The OH200 has 365 ft-lb torque at 1200rpm and 200 HP at 3400rpm. It is 400 cubic inches, 4.25" bore and 4.7" stroke with a 7.5:1 compression ratio. The flywheel, clutch, and flywheel housing from the OA331 bolt up to the OH200. I had to use the air cooled air compressor as the water cooled one wouldn't clear the thermostat housing. The OA331 exhaust manifold was re-used but the top capped off as the OH200 doesn't have exhaust heat. I designed an adapter to mate a Mack/ Cat type spin on oil filter to the OH200. Oil filters are available with combined full flow/ bypass type elements. The oil pan is a center sump. I rotated the oil drain plug 180 degrees to put it on the drivers side. This adds needed clearance and makes for easier oil changes. I changed the armature in the starter to 12V (kept the rest 24V) which spins the engine over nicely. The distributor has a tach drive; I am using a 3krpm military tach and a stock deuce speedomeer cable. I am in process of modifying a 1481 pertronix ignition module from 8 cylinder to 6 cylinder.
Overall, it's is a nice improvement in horsepower and perfectly fit my requirements for a bobbed truck.
