Borgensen steering shaft install questions
ehuppert
138
Upstate NY
Still in the midst of my frame up resto! Beauty of a frame off restoration is that once the frame and parts are blasted and painted it's really hard to bolt any rusty crap back on the truck! My steering shaft was very ugly, rag joint wasted. Perusing the web, jeep shafts (used were expensive), brand new jeep shafts apx $100, so in a spending money moment i ordered the borgensen u-joint shaft!
Going to cut the piece down tomorrow, not a big deal. Question is, doesn't look like the thru bolt hole in steering column gets used? I'm assuming i need to drill a hole in the steering column side for the long set screw?
Understand why the shaft is long and needs to be cut down, but would be nice if they made the upper joint collar use the through bolt!
any BTDT's
Eric
ehuppert
138
Upstate NY
Took me longer to type the question than it did to fit the upper ujoint and figure it out! The long set screw does indeed fit through were the upper bolt hole is on the column side. Will cut 9" off the tube tomorrow which will give me about 4.5" of collapse similar to the oem shaft. Then again, the OEM shaft was so rusted i seriously doubt it would collapse at all. But, then again again, withe plow frame and all the heftiness of the one ton frame.... If i managed to collapse the left frame horn that five inches i think the steering column collapse would be the least of my worries!
I even read the directions this time! Something about cutting a expensive piece like this makes me a little more cautious!
Eric
Doghead: thanks for the links. Had never looked at their catalog, Will be a good resource for the restoration shop i work at!
