Borrow a head bolt tool in central VA?
stupidjeep
California, MD
I had to leave the Deuce here a few months ago when the HG went, now that I have a few days off of work I am back for her. I have a 3/4" drive set, some breaker bars and the TM for HG replacement. The bolts have been sprayed with PB over the last few months, so hopefully I dont break anything.
I am hoping someone can lend me the crazy wrench, I dont have access to a welder. I am in Goochland County, but willing to drive all around VA to get one of these.
Thank you
Chris Robbins
4,815
I personally went to advance auto and picked up a wrench. I placed it in my vice and used a torch to bend it into a |_| shape. Then I welded a broken socket base to the open end. If I were to use it again, I'd add some gussets in the bends to beef it up a little. Or at least create a spline down the back of the wrench to re-enforce it. As it does flex a bit at 100+ ft-lbs. Have no fear of it breaking though. Cost $8 plus time, gas, a welding rod, exc. I was going to buy one from Saturn until I read about all the breakage issues.
frank8003
4,985
Ft. Lauderdale, Florida
Crazy Head Bolt wrench
What does a head bolt "crazy wrench" look like!?
I wanted to know about tools to get the heads off.
Apparently they are not for sale but many SS members own them or have made things that work . Some of the purchased wrenches break before getting to 160 ft.lbs.
Pictures for the General
stupidjeep
California, MD
Thanks hoop. I may take you up on that if you are available this weekend. A friend thinks he can help me out and try to fab one up, I'll see if that works first.
We got everything torn apart tonight, except for the injecter side, there doesnt seem to be much to that. I've never seen the insides of an engine before!
stupidjeep
California, MD
I made one! A local repair shop welded it for $20, and after some grinding trial and error she's golden. I got the heads off and taking them to be milled tomorrow. I was able to see where the head gasket failed.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Why not just buy the correct tool for the job. What you need is called a "Torque Adapter". The link provided is about $20 or so, I'm sure if you shopped around you can find one much cheaper. Proto J5128 Torque Adapter.
