brake adjusters
white135
Auburn, IN
Guys,
Hope someone is willing to help me out.
Hit a bit of a snag in the 215's restoration, as all the brake adjuster blocks are locked up with rust.
Out of the first four I have worked on, I have freed 3 using pb blaster and a torch. The fourth however, simply snapped the tabs off.
So, I am in need of a left side anchor block and adjusters, used if anyone has any extras they would be willing to sell me.
It would be a great help to me thanks a lot.
Eric
topo
256
farmington NM
I had the same thing happen I was able to free them up by soaking them in kroil for a few days and I was able to get them working . I will see if I have some on my parts truck that are good and let you know kenny
white135
Auburn, IN
On the outside, ie not the flat side aginst the backing plate, there should be a l.h or a r.h stamped in with an part number. Thanks so much for your help.
Eric
white135
Auburn, IN
Acually, depending on what you would want for them, and how shipping would be, I would be willing to take several of them, as it would be easier than tourching them, especially with two axles to go. Let me know.
Eric
topo
256
farmington NM
Eric the 3 I have are left (lhfe14751) and weight just over 3pounds each . I found a forth one but it is not turning and I started soaking it so I may have 4 all together thanks kenny
