Brake booster vent line question
Slate
378
Ozona Texas
My brake booster was changed from long style to short style and when this was done there is a small vent tube coming out of the top of the brake cap. It goes into a larger line that goes up to the air pressure regulator but the line was crimped and not connected to anything. Is the fuel tank vent in the same line? And where should it connect. Reason I'm asking is the brakes started working better when crimp on line was sealed but now engine is dying first at startup and later when engine warms up. Starts right back up but loses power and dies. Any connections between the two?
Sent from my moto z3 using Tapatalk
Slate
378
Ozona Texas
And should that line be connected to the air governor, not air pressure regulator, sorry about my terminology.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
Yes that should be the vent line for the brakes and fuel tank. No it should not be crimped. Is it going to the air compressor governor or is it just hooked by the air filter? A pic would help a lot. They are supposed to have a vent cap like the trans and transfer case have.
Slate
378
Ozona Texas
This is the end of line coming out of brake booster that the fluid cap is vented into. When looking at the fuel vent line looks like it is on the passenger side of the air governor in this pic they are not in same line. But my engine didn't start to cut out untill this line was crimped. It was crimped due to a little brake fluid coming out of it and air leaking out whenever brakes where applied. Also I noticed when fuel pump is shut off I hear fuel running into tank from return line, if that says anything. Have changed fuel filters an gaskets.?IMG_20190614_084820164.jpg
Slate
378
Ozona Texas
This is where that line comes out of booster. And second pic fuel vent line to pass side of governor on top brake line that's crimped on bottom
Slate
378
Ozona Texas
Opened it back up now I get pressurized brake fluid sprayinging out after brake is pressed.
Slate
378
Ozona Texas
Ok so brakes had nothing to do with fuel system was hoping for easy fix.
Slate
378
Ozona Texas
I do have air in the line here and have changed Farrel on pump right there but air won't go away. No leaking anymore.IMG_20190614_100058651.jpg
frank8003
4,983
Ft. Lauderdale, Florida
Master cylinder must be vented to somewhere, even right at the cap even. I vented mine to the dashboard, but that is another story. If it is NOT vented then that MC will fail in short order.
and..Yes the vent for the MC WAS tyed into the vent for the fuel system by original design on M35A2.
Slate
378
Ozona Texas
This helps a great deal thank you. Now I have to track down my fuel line air leak. When I rev up engine I start to notice little bubbles out of top of some injectors sometimes and then it all accumulates at end of line. HereIMG_20190614_100058651.jpg
Floridianson
2,497
Interlachen Fl.
This helps a great deal thank you. Now I have to track down my fuel line air leak. When I rev up engine I start to notice little bubbles out of top of some injectors sometimes and then it all accumulates at end of line. HereView attachment 767766
The injector return line just seem to do that but it is not a problem if the truck is running fine and all injectors popping and sounding the same. One would thing that when they say injector return it should be moving fuel all the time and one would never see any air. Not always true. I believe you fine so on to the next fix.
If you watch when they pop test an injector nothing comes out the top or return.
Floridianson
2,497
Interlachen Fl.
Sorry about the black lettering messed up on the thread and I cut and pasted it.
As for the injector return line if you look at the way it runs into the overflow valve that can go from 30 psi to 70 psi fuel pressure. The injector returns have no pressure to push that air out with the 30/70 pushing fuel up the return line so it seems like the air just sits there. As I said believe your ok.
