Brake chambers
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Thank you for all your help I will get back with you on the used one I am going to see what I can fined in new first
Did yours break off? Or knock a hole in it or what?
Sent from my SM-G935P using Tapatalk
Race1030
Cincinnati Ohio
No I didn't brake off it is leaking between the emergency and service Side of the chamber I have replaced all of the diaphragm and I am still getting a massive air leak
simp5782
9,339
Mason, TN
Leaking air thru the clamp/ bevel area? You used a # 16 diaphragm correct? the inside is 12 and spring side is 16. It probably is a weak clamp over the face of the spring brake being warped causing a leak.
