brake drums wobbling
marks86
Latham NY
My truck is still shaking, I narrowed it down to the rear end.... WIth the rear end of the truck on jackstands with the tires OFF the truck the drums are wobbling back and forth has anyone ever hurd of this issue?
marks86
Latham NY
They only way I know they wobble is the truck up on jackstands I put the truck in gear and the drums wobble as it increases in rpm
FMJ
37
Las Cruces, NM
Not sure where to go with this. You can check the axles for trueness by taking them out and rolling them on the floor of the garage (hard flat surface)
1,808
While up on the stands, run the wheel mounting surface against a dial indicator. If the wms is nearly true than a bent drum is likely. It could have been dropped on a drum and bent it that way.
marks86
Latham NY
I took the drum off for closer inspection and I found the drum/hub assemblie only has one bearing with one race... I find this weird because I went to off road design to order a rebuild kit and that comes with two bearings per side now I'm confused
1,177
Post a picture.
Perhaps your axles are not the originals.
marks86
Latham NY
I just put it all back together for now, but I swear there was only one bearing I took the lock ring then the key way out along with the locknut....behind that was a bearing... So I slipped the whole drum off at that point and found nothing else inside....can someone please clarify that there should be two nuts before the hub should come off along with two bearings
1,177
Just look at the parts tm.
rtk
446
Lockport N.Y.
Sounds like you are missing something , should have a inner and outer bearing . Who knows maybe when it was going to auction , maybe they left a few parts out . Can not believe you have been driving it . Like the troops say , Look at the TM's , they have pictures , you can see what we are saying . Interesting , unless somebody slipped in a different axle , PICTURES would help a LOT .
