Brake Fluid Leak Around Master Cylinder Cap????
trider
Seminole, OK
This past weekend I added a remote brake fluid reservoir to my deuce and a half. I now have a brake fluid leak from somewhere on the master cylinder. It appears to be coming from the top and looks like its coming out around the threads of the master cylinder cap. I dry the top of the master cylinder off them when I go back and check it I have fluid around the master cylinder cap. Has anyone else had this happen when adding a remote reservoir? Do you think I should add teflon tape to fix it?
Woodsplinter
Phoenix/AZ
I had the same problem and sealing the threads of the m/c cap will not help. You need to put a thin washer under the cap. I think I used a thin copper washer from a hardware store. My leak was coming from where the bottom edge of the metal cap meets the m/c, just above the threads. Hope that makes sense- it's past my bed time.
cattlerepairman
3,276
NORTH (Canada)
A copper washer is great; a flat plastic washer from the plumbing section (the ones used for sink traps; 1 1/4 inch I think) also works very well. I had the same problem after adding the remote reservoir...constant loss of brake fluid.
trider
Seminole, OK
In the small town I live in we have one parts store and an Ace Hardware. Th best thing I could find is a rubber o-ring so I am going to give that a shot if it doesn't work I will have to find a copper washer in a different town.
1,176
Why not look up the NSN and Google search it?
steelandcanvas
85
Southwestern Idaho
Your Ace Hardware ought to have that 1 1/4" plastic washer and it won't deteriorate like the rubber O-ring.
trider
Seminole, OK
I went theough ever little plastic bin with washers, o-rings etc couldn't find anything so I asked the guy and he said they didnt have anuthing lile that. The o-ring stopped my leak so im leaving it alone until it start leaking again then I will look in another town.
cattlerepairman
3,276
NORTH (Canada)
Murphy says: "If it ain't broke, do NOT fix it". Good plan.
jbayer
St. Aug., FL/ McGrady, NC
It really depends on what that O-ring is made of.
I think the DOT 5, being Silicone based Is not as harsh on plastic/rubber like DOT 3. (Assuming it is DOT 5)
Not meaning it wont ever deteriorate rubber/plastic.
Just my2cents
1,176
Why not just get the correct seal?
trider
Seminole, OK
It is DOT 5 brake fluid and I will continue to use the o-ring until it starts leaking then I will get a plastic or copper washer.
rustystud
2,815
Woodinville, Washington
Yes but where its leaking, it will still leave him with a full master cyl, just like a stock truck.
My comment was towards the "don't mess with it if it's not broken" idea. Not this fix in general . In the Marines and here at work I have been required to make field expedient repairs. Some turned out to be a real good fix, but in general it is better to use the factory part as they are the ones who have spent the money and time to research what will and will not work.
MyothersanM1
19K M1 Armor Crewman
418
68
Culver City, CA
Try these...
I did the remote MC reservoir mod on my M818. Mine seeped at the cap with the copper washer. I replaced it with this...Double Seal Buna-N O-Ring...from McMaster-Carr. Buna-N , AKA Nitrile, is compatible with silicone. Mine is holding fast for now.
I believe, therefore I don't know ;), the Deuce MC cap may be smaller diameter. If you go this route, do not over tighten as the o-ring will bow out on one side.
