Brake fluid
GUNNY 155
elgin illinois
Given that silicone based brake fluid is what the mil specs calls for on M37's I was wondering if that is what folks are commonly using. Also has anyone had leak problems using the silicone based fluid.
NDT
6,233
Camp Wood/LC, TX
Silicone (DOT 5) works great in M37's. Start with new/rebuilt master and wheel cyls and blow out the lines. Will be the last time you work on the hydraulic system in your lifetime.
gungearz
northwestern indiana
You can use whatever brake fluid you want in any system.... PERIOD but make sure whatever you use, you don't mix dot 3/4 with dot 5... military uses dot 5 because it does not mix with water and cause the brake lines to rot out.... it's more of a insurance for equipment then anything... dot 3 and 4 can be washed off, mixed with water and corrode your lines... dot 5 cannot....
ton10291
Minnesota
What happens if a little DOT 3 gets mixed with DOT 5 as would happen if the DOT 3 was bled out and DOT 5 added until all bleeders ran purple?
bigmike
355
Dixon CA.
I've done this and have had no issues (5 years ago). I had trucks where folks mixed the liquids. If it jelled, you need to change out components (Master cylinder, wheel cylinders, airpack etc). If no jelling, then a major flush until you see DOT 5 bleeding that looks so good you'd put it right back in your Master cylinder, you'll be good. I've had zero issues since doing this.
