- 8,479
- 2,614
- 113
- Monrovia, Ca.
Took the left side apart tonite after work, All looked good, bearings, wheel cylinders, springs and all the little hardware. Cleaned, packed the bearings, installed the new shoes, new seal. Backed the adjusters all the way off, top and bottom ones, but the drum was very tight going on. Could only get max of .010 clearence on the rear shoe and it drags at the lower right area all the way around. The front seems fine. I have read the TMs, a few times. Anyone had this issue? How many times can you take the hub off w/o replacing the seal again? Help me
