Evansville Collector
- 0
- 6
- Evansville, IN
Hello,
Ever since I bought my XM813 it has required a triple press of the brakes. 1 pump little to no braking force, second pump, much more break power, third pump great brakes, but if you push too hard prepare for tire chirping.
I found a leak where the all new brake lines connect to the new master cylinder. It was a very small leak but my theory is it was letting air in the lines. Once I removed all of the connections and re installed it leaks much worse to the point where it has little to no pedal resistance and the fluid pours out. I have attached a picture showing where the current leak (red arrow) comes from, it bubbles out of that connection. The yellow arrow I believe was the old leak, but I removed a copper washer that was there and now it does not visually leak anything from that connection.
The picture showing all of the connectors is what it looks like off the truck. I am showing the connecting surfaces. The little bushing in the middle was given to me by my dad who thought it might help, and it appears that it might fix it, but before putting that between the connectors and tightening down I wanted to run it by you guys. I have been all over town and the various truck equipment places do not have any "better" fittings. One suggested I get the higher end JB weld and permanently connect them. But before I do something that can never be reversed I wanted to see what you recommend. Thanks everyone.
