- 217
- 114
- 43
- Oahu, Hawaii
I have a 1966 M35A2. Due to my rear drivers side blinker/stop and marker not working I decided it was a good time to replace the rear wire harness, and driver rear bulb housing. Even after replacing both I only have a extremely dim turn signal , no stop or marker. What else could it be?
I did try to tighten up the back of the light selector switch. The turn signal works on both fronts and passenger rear. I did just use a flap wheel to make sure the driver rear is grounded.
