Brake Light Switch Upgrade Questions
Straightpipe
I'm getting ready to install the brake light switch upgrade on my truck. I received the switch, a tee fitting, & an elbow fitting in the kit. I haven't been able to find an article on this installation. It is not apparent to me which line the switch goes into. One must be the supply & the other one is pressurized when the brakes are applied. Is it necessary to cut the line & re-flare the end? Any help would be appreciated.
Mark
cranetruck
75
Meadows of Dan, Virginia
I think the switch in the hydraulic system (on the end of the slave cylinder)is a better way to go.
You will have brakelights whenever there is pressure on the brakes.
If the switch is in the airline, then no air pressure = no brake lights, but you can still use the brakes. Around 400 psi with foot pressure alone compared to about 1,800 psi with air.
About the reliability, the hydraulic switch is as reliable as any other part of the brake system, IMHO. Took one switch apart once and a membrane within the switch would have to fail, not the electrical contacts.
The only concern would be the manufacturer's pressure rating of the switch.
NAPA sells the hydraulic switches, about $8.00 I think. Memphis sells the NOS ones for about $35.00.
Don't know what the air line switch plus fittings cost, but certainly more time to install, that's for sure.
Just my 2 cents.
Crazyguyla
124
Altus, OK
The military switched to an air line switch because the hydralic switch could possibly be knocked off during off road operations. it must have happened for PS magazine to cover the subject so many times *L*
2cents
Marcus
Straightpipe
Thanks guys. I'm going with the air switch because I've already got it & it was my understanding that the hydraulic switch could blow out, causing loss of brake fluid, which doesn't sound like much fun. Maybe it's only a concern during offroading as Crazyguyla says but I'm not taking any chances. I've already replaced the switch with a NAPA one a year ago & it's already quit working.
